Hi there,
Today I planned to give my car a good clean ready for the winter. I have been planning this for a few weeks now, and thought it would be a good idea to clay my car before waxing it, seeing as I have heard good things about clay bars! My black 05 LCR has never been clayed before so I was looking forward to the results!
I bought a Bilt Hamber Regular Clay Bar as it won the Auto Express clay bar awards the last two years running and I liked the fact that you could simply use water as lube for it... http://www.bilthamber.com/pro-introduction.php?cname=Clays, Wax :: Polish&name=auto-clay regular
So back to today, after I washed the car as normal I dried it quickly, not as thoroughly as normal as I would be wetting it to clay it!
I started on the roof, and I used lots of water in my spray bottle wetting the roof and the bar, I rubbed the whole roof and then dried it with a microfibre towel.
Well I was horrified by the result, there were cloudy white spots here and there and in particular lots of little tiny scratches all over the roof!
I thought oh no what have I done?! ![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
I then decided not to carry on with the clay bar (obviously!) and spent the next two hours polishing the roof and its 95% better now, so I am happy.
What I want to know is were did I go wrong with the clay bar?
I washed the clay before using it as per the instructions it came with and I used lots of water on the car as lube. TBH the clay bar only got slightly dirty, a bit of green on it, but i thought it would have been a lot more soiled!
I have just looked on you tube for a guide to using clay bars, and one person said make sure you don't push too hard with the clay bar or you will scratch the paint. Well I don't think I pushed hard at all, but certainly harder than just using the weight of the clay which is what the person on you tube said to do. Is he right?
The only other thing I have read on the internet since is not using "special detailing lube" will cause scratches, but Bilt Hamber say you can simply use water as this is designed to work with water as a lube!!!
So what are peoples' thoughts? Did I simply push too hard? I really don't know what else to think!
I certainly wont be using a clay bar again, unless I can be convinced otherwise!
Thanks,
James
Thanks,
James
