HELP!!! Electrical Problem
Aug 20, 2005
529
stafford
I have a Ibiza Mk3 2001 Sport TDI. Got in it this evening drove a little way and the ABS and the TC light came on, also the red warning light and i'm getting a buzzer sound. The indicators have stopped working , as has the wipers and washers, the heated rear window has also ceased to function, i have checked all the fuses and they all look fine. Any Ideas.:confused:
Aug 20, 2005
529
stafford
I took it to a garage, Midland vw who diagnosed it using vag com, not got the car anymore, but the relay wasn`t expensive from what I can remember.
Stupot808
I have had a similar problem that the abs and traction control light remain on after starting my ibiza mk3 the wipers indicators and light cease to work I took it to the garage and they diagnosed it as a faulty ignition switch they cleaned it up and the fault seems to have disappeared they said the repair wont last fortever bu an ignition switch on ebay are inexpensive hope this helps for anyone else with a similar problem cheers
