Help.... vag-com fault codes
-pseudonymous-
681
Hello guys. Hope somebody can help me out. My mates mk3 Ibiza 1.6 sport has recently developed a list of faults. I plugged the car into vag-com after the engine management light appeared on the dash, and the following faults appeared:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17923 - Intake Manifold Valve (N156): Short to Ground
P1515 - 35-00 - -
Thanks in advance.
Jun 28, 2001
1,533
and the car still runs?
delete them all and try it again after 1 hour of driving it then see what dtc's youve got.
with them codes it would be running a little bit rough.
possible earthing problem has more than likely caused that or flat battery at some point
-pseudonymous-
681
Thanks for the speedy reply! Yeh the car seems to run fine. One thing we have noticed though is very poor fuel consumption.
I did clear the faults, but they re-appeared after starting the engine. The battery hasn't run flat, but i did disconnect it after the faults appeared to reset the ecu.
Any other suggestions? :shrug:
Cheers Ollie.
-pseudonymous-
681
Thanks daz. Will check for that. ECU's under drivers side of windscreen yeh? Just check for moisture?
-pseudonymous-
681
Hello mate. Yeh i found a blown 10a fuse for the lambda sensor i think. When i replaced it all the faults cleared only to re-apear when the fuse blew agen :lol:
So obviously something is electrically amiss to keep blowing this fuse. Maybe a dodgy lambda sensor?
