ozaudio
386
north west
so ive been getting faults on my dash, EPC and engine management light coming on, so I got home and dragged my pc otside and used vcds lite, I got some codes up
VCDS-Lite Version: Release 1.2
Tuesday, 10 September 2013, 14:32:56.
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT 0002
Coding: 11510
Shop #: WSC 13112
VCID: 719556C728B1
VSSZZZ1MZ2R019705 SEZ7Z0A1222207
4 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17947 - Shareware Version. To Decode all DTCs
P1539 - 35-00 - Please Register/Activate
16705 - Shareware Version. To Decode all DTCs
P0321 - 35-00 - Please Register/Activate
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
Readiness: 0010 100
I then cleared these codes and it wouldn't even start now!!!!!!!!!!!!!
so I plugged vcds back in and a fault came back
ddress 03: ABS Brakes Labels: 06A-906-032-AJQ.LBL
Controller:
Tuesday, 10 September 2013, 14:45:04.
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11510
Work Shop Code: WSC 13112
VCID: 719556C728B1
Additional Info: VSSZZZ1MZ2R019705 SEZ7Z0A1222207
1 Fault Found:
P0322 - 35-00 - -
I left the battery unplugged for half hour and then it started again... something must of reset itself? would you replace the crank shaft sensor or do you think this could be something else causing all the problems? :cry:
need to take the cam position sensor off and clean it with some contact cleaner
have a look at the terminals and make sure both sides are clean and not rusty or going green
it may be mucky or it may well be knackered
nath
