Hey guys
LukasFR16
Hey everyone.
I have recently bought my Leon FR 2.0TDI 184 2016. I guess it’s not as exciting as Cupra most of you here own but I still lovable this nippy little thing
I do have few small issues. One I have already found a solution for. This was door cards vibrating when volume above 50%.
Second one when going over speed bumps I get a lot of plastic squeaking noise from all around. Is this caused by sport suspension or is ir common fault? I would appreciate any suggestions.
Lukas
Jimbobcook
6,176
2,562
Welcome to the forum Lukas,
I've been in a 184 and they are pretty quick indeed, I would recommend posting about your issue in the MK3 section as currently its quite busy so you should get a decent response.
The link is here if you need it.
Hope you get things sorted
Also it maybe worth having a look at the link in my signature for the national meet in July which is hosted in Donington if you're close by, there's alot of MK3's going.
Deleted member 103408
welcome to yhe forum Lucas post some pics when you have enough post's.
Short answer on a lot of leons they suffer with rattles as @Jimbobcook said post in MK3 section somebody should be able to help
Enjoy the car they are all fun to drive
