Hi Guest we, are working on an upgrade to the forum this week, meaning the service may be unreliable at times and there will be some planned downtime at some point. Stay updated on this thread.
Hi
Wonder if anyone can help?? On my high level brake light one of the bulbs in not lit is this an easy fix i.e single bulb replacement or does the unit have to be replaced? and the cost if anyone knows. Thanks
The car is 4 years old and I took out an all component extended warranty in March and am not sure if this would be covered. May give Seat CS a phone and see. The wording in the warranty policy is a bit ambiguous so I'm not sure.
When I was looking at extending the warranty - I was told if an LED unit failed - they would cover it.
If it cracked or leaked but the led's were all still working - they would not cover it.
Mine was replaced under extended warranty as the unit was cracked and is a known fault.
I enquired about the cost and was told if not under warranty would have been in the region of £ 95 fitted
I also have this issue so I think I will need a new unit. Also whenever I brake the high level brake lights flash really quickly. Would you expect that to be the unit or a brake light switch? Thanks
