fauldzy
I have a 2003 Leon Cupra (180bhp). Today as I was driving home I hit a major traffic jam and I was mostly idling/start stop for an hour. After about 50 minutes I noticed the engine running slightly rougher than usual. I looked at my temp gauge to discover the needle was just under 105 degrees and slowly dropping, until it got back to the regular half way position of 90 degrees.
I panicked as I had never seen the temp gauge read anything over 90 degrees in the 3 years I have owned the car, not even during the hot summer on long journeys!
No more than 5 minutes later and the needle was starting to creep back up again to 105, upon where it stayed briefly before dropping back down to 90 degrees. This all happened during the traffic jam and thankfully I was coming up to the bottleneck. Once freed up and on my way, for the remaining 5-10 minutes of my journey, the needle stayed at 90.
Coolant level is at the appropriate level, so no leaks. The car is serviced at recommended intervals with the dealer. Cam belt along with water pump was replaced earlier this year at dealers. Coolant sensor was also replaced with the 'improved' green variant a couple of months ago. This was after the original produced an EML and vagcom then flagged it up as faulty.
So is this temperature reading considered 'normal' or something to worry about? The Owner's manual does state this as a 'normal' temperature, but 'when the engine is working hard and ambient temperature is high' neither of which was true in my case.
The only other theory I have is that the car was not moving enough for an extended period of time, to encourage regular airflow through the rad.
Anyone shed some light please? I just want to know if I am going to break down anytime soon, or I am simply worrying over nothing!
