hillbill
Hope you like......
Will update as parts get fitted.
Current Spec Of : T18 DUB
Golf Mk4 1.8T | 2000 | 3dr | Straight Black L041
Engine :
1, 1.8T AGU ( large port )
2, K03 Hybrid turbo ( Cr turbos k03 hybrid to k04 RS6 spec )
3, Forge K03 Actuator with uprated yellow 9psi spring for hybrid turbo ( still to be fitted )
4, JBS K03 Tubular manifold
5, Milltek 3” downpipe and sports cat ( heat wrapped )
6, Scorpion 2.5” cat back exhaust system with discreet tail pipes
7, Forge front mount intercooler with black silicone hoses
8, Forge 007p diverter valve with uprated yellow spring for hybrid set-up ( uprated spring still to be fitted )
9, Forge turbo silicone hose set in black
10, Forge coolant silicone hose set in black
11, Forge silicone AGU k03 turbo intake pipe in black
12, 3” maf housing with AGU sensor fitted ( still to be fitted )
14, K+N panel filter
15, Genesis Green 415cc injectors ( still to be bought and fitted )
16, Audi R8 oil and coolant caps
17, Mocal Oil Cooler ( still to be bought and fitted )
18, Optima red top battery model: RT S 4.2
19, ECS magnetic sump bung
20, ECS 180 degree thermostat
21, ECS 180 degree fan switch
22, B&M quick shifter ( still to be fitted )
23, VF Engineering engine, gearbox and pendulum mounts ( 3 mounts in total )
24, Stage 1 remap ( need custom map )
25, Seat leon cupra R 4 bar fuel pump
26, Newsouth power intake manifold gasket ( reduces heat transfer )
27, Hi-Flow aluminium radiator 38mm core
28, 42 Draft Designs oil catch tank ( brushed finish )
Chassis :
1, KW Clubsport top mounts ( camber and caster adjustable )
2, KW v3 inox coilovers ( stainless steel - height, damping and rebound adjustable )
3, FK front anti-roll bar
4, FK adjustable drop links ( front )
5, H+R rear anti-roll bar
6, Genuine BBS LM alloy wheels 18x8. 5 / et25 / 5x100 pcd / LM145 / 5 wheels in total
( polished lips and painted silver centres )
7, Toyo proxis T1-R 215/35/18 tyres all round
8, ECS Stage 2 v2 front brakes ( light weight 332x26mm 2 piece floating discs
( drilled and grooved ) and Porsche boxster 4 pot brembo calipes in black )
9, ECS stage 1 rear brakes ( light weight 308x8mm 2 piece floating discs ( drilled and grooved )
10, ATE super blue racing brake fluid
11, Goodridge braided stainless steel brake hoses x 4
12, Superpro polly bushes ( rear beam, wishbone, steering rack, anti-roll bar ) ( to be bought )
13, Powerflex rose jointed front wishbone rear bushes ( to be bought )
Interior :
1, Recaro standard golf mk4 gti seats retrimmed by TrimStar in half black leather with genuine vw velour centres, using light grey/silver stitching also recaro embosted on the top centre of all four seats. Recaro golf mk4 gti front head rests x3 fitted to rear seats ( smaller than standard rear headrests ) ( Retrim includes: front and rear seats, front door cards, rear quater panels, handbrake, gear gaiter and parcel shelf )
2, All trim painted piano black: drivers and passangers inner door grab handles, centre dash trim, vdo gauge holder
3, B+M short shifter in black
4, R32 steering wheel
5, R32 pedals: accelerator, brake, clutch
6, R32/Bora illuminated vents ( R32 illuminated vent loom )
7, W8 interior light ( W8 interior light loom )
8, VDO gauges and single din pod ( oil temperature, oil pressure, turbo boost )
9, R32 door openers ( brushed aluminium handles )
10, R32 handbrake ( brushed aluminium button )
11, Genuine vw luxury mat set x4 ( black )
Ice :
1, Optima red top battery ( model: RT S 4.2 )
2, Pioneer headunit
3, Alpine components front
4, Alpine speakers rear
5, Earthquake amps
Exterior :
1, Colour straight black ( paint code L041 )
2, Bonnet de-badged, welded and smoothed
3, Fk de-badged 2 slat grill
4, Front bumper de-badged, plastic welded and smoothed
5, Boot de-badged, de-handled, welded and smoothed
6, Beetle boot catch/release, operated by rear wiper stalk
7, Rear screen de-wipered
8, stubby arial
Planned Mods :
1, Genuine vw shallow sump
2, uprated clutch and flywheel
3, lsd
4, R32 front setup i,e sub frame, wishbones, hubs, quick rack
5, Pair of genuine bbs lm's 18x9.5 for the rear
6, maybe big turbo ( did have an rhd apr 3+ kit but sold as need cash flow )
Maybe R TECH as i've only heard good things about them.
KW v3 coilovers with KW clubsport camber/caster adjustable top mounts
That's very sexy mate, but R tec to map it why ????? , those coilovers look the sex
Just heard good feedback about them and they are local to me....
If I hear of other tuners that are good at remapping a hybrid then I will consider my options??
Heard stealth racing are good and there localish to me.
its a nice clean looking motor. :clap:
vince@stealth can do a good job on your me3.8 ecu
Might just give stealth a call... Andy from TUK recommended vince for doing my remap...
Something you might be able to advise me on with your wealth of knowledge, what injectors would you go for with my spec hybrid setup, either genesis 380cc or genesis 415cc?
sweeeeeeeet ride man wud look better if u dropped it a lill bit more to hide the top of the tyres.
Cheers.
The stance is all in hand : ) The helpers on the front and adjusters on the rear are coming out, a chassis notch is being done, engine spacers are being made for the vf engineering mounts, front arches are being rolled, shallow sump is being bought and the R32 front chassis setup is being fitted ie wishbones,hubs,subframe,quick steering rack and anti-roll bar as my Kw v3's have the R32 anti-roll bar drop link mounts, it's gonna take a while though because of time and funds.
Oh and I'm after a pair of genuine bbs lm's in 18x9.5 for the rear ; )
R tech mapped a ko3 hybrid on my mates agu golf and they blew the turbo, they then tried mapping it again as turbo technics sent them another turbo and they blew that. He's now back on standard ko3 turbo. Ask in the badger bill section on here for mapping ;)
Vf engineering engine, gearbox and dogbone mounts before i fitted them
Dogbone mount still to be fitted
Larger core alloy radiator that i bought, just needs fitting
