How to bleed coolant ?
Mike66
19
Does anybody know the correct procedure for and /or bleed screw locations for BXW engine code please?
Have to change hose but would like to clarify before retopping up.
Many thanks.
DEAN0
Old Git
Feb 1, 2006
5,423
Preston - UK
Many thanks.
Cant speak directly for the BXW engine but most of the others is just a case of filling up the coolant ( make shure it's G12 or G13 compliant ).
Then start the engine with the expansion bottle top off and allow it to circulate the coolant.
Any air pockets should find their way to the expansion bottle and the level will drop.
Keep topping the level to the mid point.
As soon as the level seems to be rising slightly - put the expansion bottle cap on.
run it till the fans kick in.
Mike66
19
Thanks mate.Had bleed screw on last car and have a bleed /air hole on Passat which I let bubbles clear from before securing pipes-wondered if it was same .Thanks for advice.
Mike66
19
Haynes manual for Mk 4 says pop out coolant sensor until water is running through then replace and top up.By the time I read this I had assumed would self vent did short journey and level dropped enough to require a litre of topping up.However did pop sensor out and full.Think may only be necessary to do sensor if you have fully drained system not just for top pipes .
RUM4MO
8,082
1,107
South Scotland
I think that the issue with the Passat would be due to its engine sitting higher than the heater hoses and the fill point being quite low.
