Tool Required:
Small flat blade screwdriver
Large flat blade screwdriver
3/8 Rachet
Medium size extension
13mm deep socket
6mm socket
T20 torx screwdriver
Stanley knife
Insulation tape
Wire stripers
Side cutters or scissors (To cut wires)
Solder iron
↓Firstly I removed the rear seats which was easy enough↓
Pull the seat bases down then look underneath the seat bases to see to rod (↓SEE BELOW↓)
You should then be able to remove the base of the rear seats these are nice and light!
Remove the rear head rests.
Then pull down the back of the seats to reveal the hinge (↓SEE BELOW↓)
The backs of the seats can now be removed the two seater back is heavy.
3/8 Rachet
13mm deep socket
6mm socket
Stanley knife
Insulation tape
Wire stripers
Solder iron
