How to remove rear door panel? 5door 1.4 sport
deanw34
I need to remove the door panel for replacing the rear loud speaker. Where are the screws and clips located?
Any help please.......
Pictures are golden! Thank you for any help.
5509433
949
7
Braintree, Essex
Seemed like a daunting task at first. But it relatively easy.
I havnt got pictures but i can try and explain.
Youll need trim tools.
Pry off the pull handle cover and the material trim that will reveal some torx screws.
Undo the 2 screws revealed from removing the handle cover. and the handle should pull free.
After removing the trim on the door card youll need to undo the clamps on the glass and slide the glass up. (i secured the glass to the top by duct tape.
There is 1 screw the the bottom of the door card, undo this but not all the way, say 10mm?
There is a connection in the top right that I believe needs to be disconected.
Unless im missing any other screws, the door card, along with the window regulator should pull free.
5509433
949
7
Braintree, Essex
Oh ans if your looking at replacing the speakers, youll need an adaptor to fit them. MDF doesn't work so well as the speakers are on the door card and not the door itself.
deanw34
Hi - thanks for the reply & info! :rofl:
yep looking at changing speakers cus one is busted in the back & just crackles!!!
thnks
