hubcentric spacer
Feb 10, 2012
617
Newquay
is it possible to get 10mm spacers that you can use existing bolts on ie spacer mounts onto hub then wheel onto spacer or is it only the larger ones?
Redemption
1,771
Hampshire
Most of them come with the extended bolts that you need anyway. Maybe drop Damien at DPM a quick message in his Forum Sponsor section and see if he has the type you're after?
Feb 26, 2009
5,275
Wolverhampton
I don't think a 10mm spacer is thick enough material to do what you're suggesting, the standard bolts protrude more than 10mm behind the wheel. You could use shorter bolts, but if you're having to replace the bolts you might as well use extended bolts and go straight through to the hub.
