Hello,
I’ve been dealing with a humming noise for quite a while now. It starts whenever I go above 50 km/h and becomes noticeably louder around 120 km/h. At higher speeds, the general road noise starts to mask it.
Last year, I had a bad front left wheel bearing replaced by a garage. After that, I ordered two SKF bearings for the rear axle and one FAG bearing for the front from Amazon.
This year, both rear SKF bearings turned out to be bad, so just yesterday I replaced them with two FAG bearings ordered from Autodoc. Unfortunately, the noise is still there.
Here’s what I’ve tested so far, but I still can’t find a clear cause:
Any ideas or suggestions would be greatly appreciated. Thanks!
I've added a video of the noise: Seat Leon Cupra 280 Humming Noise
- Driving side to side to see if the noise changes - no difference.
- Went under the car with a stethoscope and checked both front wheel bearings - couldn’t notice any obvious difference.
- Checked the wheels for play (up/down and side-to-side) - no play.
- Swapped to a different set of wheels with winter tires - the noise remained.
