I have done one stage 1 with a 130hp and 225Nm results and a Stage 2 w 144hp and 240NM.
I could have go a bit higher on torque but because the stock clutch , the client didnt want to take the risk
Reactions: SimonSystems
Thank you, my friend...
I've had a stage 1 re-map installed - BHP is up to 135 - everything else is standard. What would I need to change to be compatible with a stage 2 re-map?
Simon
A decat downpipe or a highflow one + less restricted air filter (i.e K&N) would be a good idea.
You can keep pushing more boost with the stock parts but because the restriction of the CAT, temps will go pretty high and you have a risk to damage the turbo in a long term.
Same for the clutch, but you can always try. It is more up to the tuner.
