Is injector #1 faulty?
C50
32
I am having issues with poor mpgs despite changing thermostat, maf, map, new turbo, de-gunked intake manifold, egr removed, adjusted synchro/ torsion values...
I started to look at the injectors on vcds but not sure what I am looking at. Could somebody clued up have a look at my csv log and advise pretty please?
https://www.dropbox.com/s/5q289jds29g4jhr/LOG-01-013-010-xxx.CSV?dl=0
I used viewed as graph and deselected everything but injectors on kiksu.net/
Sturtz1987
125
21
Ayrshire
What did you do to adjust your torison settings? That's where I get the big difference in my Leon. Depending where I set cans either gives me low down power or crazy high end power.
Sent from my BLA-L09 using Tapatalk
C50
32
It was -1.7 and flickers to 0.0KW. After adjusting it is now 0.0 and fluctuates to 1.1KW alternately. I loosened the 3 bolts and rotated the cam to adjust
