lambda problems...i think?
blak ice
67
Hi.....I am hoping I can get some proper help:
I did a scan and got these results:
Controller: 6K0 906 032 Q
Component: ME7.5.10 S100
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0000 0000
I have since changed the air filter, the sparks plugs and the fron lambda sensor....but i still have the same problem:(
my 2000 ibiza, the revs flutuate (sp) and sometime dips so much it cuts out. The car feels like its hesitating and struggling at times.
please help...i havnt got a clue what is the problem. could is be the ecu?
blak ice
67
i dont hav vag-com...my ebay cable doesnt work:(
so i will disconnect the battery. and try that
blak ice
67
update
I have disconnected the battery, but it did not do anything...i think it has made it worse!
someone once said that I should check the boost leak or something like that, where would i find this to check it and how do I check it?
has anyone bought anything from www.ecufix.com, i am going to buy a vag com cable from them.
blak ice
67
so many ibiza experts and know one can reply:(
i would like to disconnect the maf, where do I find it? does anyone have any pictures.
an where is the ecu?
