Latetly my oil temp. and at times the coolant temp. rise above the norm - oil by 10 degrees and water - the needle moves to 105 degrees at times but mostly stays on 90 or maybe rises slightly above that.
After a Vag-COM test, my mechanic noticed the Lambda correcting % is at Max, ie 25% and suggested I replace the Front Lambda as it's causing the lean mixture hence the rise in overall temp.It logs as a fault code (intermittent) and twice remained constant with CEL on.
My question is this -
If the ECU is correcting the mixture how urgent is replacing the Lambda probe?
Could the knackered Lambda really cause this rising temp. readings?
Kind of worried to shell out the money for probe if it doesn't rectify the rising temp. problem which could be anything from thermostst to blockage or whatever
I'm due Monday for the repair so would really appreciate your input guys
Thanks in advance
Thanks in advance
