LC and single pass intercooler
Dec 19, 2006
673
Hi, looking to see if there is a guide how to change my twin pass front mount to a single pass one ready to go big turbo hopefully as the pipe runs are easier and can flow better into a new intake manifold with the throttle body at the other end.
Seen a few pics of Cupra's that have had it done but can't find a guide or a list of parts required to do it and where the pipe runs go. I have the forge front mount fitted at the moment so wasn't sure if a single pass one would mount in the same way or if brackets would need to be made up and so on.
Any help or info would be much appreciated
cheers
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Phil_c has done it to his lc but I'm pretty sure if you run the same set up as an lcr ie throttle body and charge pipe the pipe routing will be the same as an lcr :)
Dec 19, 2006
673
How does it turn down on the turbo because isn't your turbo in a different position and orientation?
Dec 19, 2006
673
Also what advantages are there to running an R32 size throttle body over my standard one and what size pipe does it take on the inlet?
Dec 19, 2006
673
Ok mate will let you know won't be doing for a while though as need to get all the bits to do it. Anyone got any pictures of the pipe runs and sensor and cables that need extending
