Hi need some help, I got some 3sdm 0.05 wheels and I worked out the measurements wrong the don't clear the calipers Brembo 4 pots so could some one help, they are 8.5 wide and et 35 am i right in thinking iv widened the wheel by 12.5mm so half that which is 6.25mm minus the 3mm from the offset so with a minimum spacer of 3mm it will clear if not does anyone know what mm spacer I will need thanks in advance
