this is mine.. all but windshield
It can be done but only on the outside.. becouse small window on the back is plastic and standar vinyl is not aplicable on the inside... you need vinyl for the outside for rear handle window...
everywhere
By leviathan18, shot with DSLR-A200 at 2008-07-29
There is a company here in the North West called Cooltint, they've been going for years (they do a lot of office windows as well) we've used him a lot and he uses a spray on the inside of the rear perspex window. He tells me that the reason film shouldn't be used is because the plastic emits a very low volume of some sort of gas which will cause the film to bubble over a period of time. Whatever the technical reasons are, he comes out to you and does a great job. The guy i deal with is called Tony, 07949 110255. This has to be a better solution than cutting out the perspex and bonding in the FR/Stylance window which often still isn't dark enough.
