Leon MKIII Hood Saver and OBD Saver
L1Leon
Hi¡
As you know, leon MKIII have some security problems. One of them, is the OBDII connector, as you know, if you have access to this connector, you can disable the inmobilizer. To "fix" this problem, i have made a OBD Saver or OBD blocker, i mean, a OBD lock.
With this i will try to solve the problem with the ODB and will be more dificult to thieves to stolen it¡
Another problem is related to the Engine Hood, you can open it without open the car, there is a piece near driver wheel, where you can open the Hood. They can acces from the wheel arch. After that they can change you ECU.
Thanks¡
BR
Reactions: Daz3d
