Leon radio woes
ad93022
17
Hi there,
Changed the head unit out in a leon to replace it with something with an aux in, used the new unit and its respective ISo harness and had no power , tried 3 other radios with harnesses and still no dice . Eventually went back to the original and now that wont work! Checked two of he head units in other cars and they're fine, also checked fuses on back of radio and. Car fuse on right of dashboard ( no 42 ) ?
Is there another fuse that needs checking ?
Am I best off trying to run power off the cigarette lighter if alls else fails?
Ill check output okay he both switched and lie and earth continuity whennibget down there with a multimeter :)any help would be appreciated
PSX
271
Advise not running off the 12V cigarette lighter - it should be individually fused, and the cig plug is always live in the Leon.
Alex
ad93022
17
Does anyone know the numbers of the two radio fuses? Are they 14 and 52?
SWANSWAY CUPRA Dealership
