Oct 15, 2022
11
I have had numerous problems over the past months with my cupra fair to say the pockets a bit sore so hopefully down to the last issue I have an exterior light fault that causes the flashing warning light when it used to be solid on believe from aftermarket lights. All are working fine with no issues any ideas what causes the flashing fault
andylong
494
I believe that errors with that can make that light flash.
The sensors are attached to the suspension front and rear.
See if your headlights correct for inclination, most noticeable if you park on a slope and start the engine, the light beams move noticeably. For me anyway.
Reactions: Cfallon
Oct 15, 2022
11
Is there anyway to reset them as I have lowering springs ect just had a new engine also so everything was stripped down
andylong
494
Hmmm, they are adjustable and fragile. If they are undamaged you can adjust what level is. I don't know about reset, they have an arm which attaches to the sensor. The process is unfamiliar to me
