Lights won't switch off
Blaine
195
Today a message came up on the dash saying "error light fault" I Noticed the lights are now constantly on even when you put the switch to off or side lights position! everything is working fine , lights self levelling etc, just can't be turned off when the ignition is on, anyone else had this? LED lights. Thanks
robby71
648
91
Yorkshire, UK
DRLs do stay on when ign is switched on - can't be turned off (should be just front lights not rears)
Have you checked for a bulb out re the message?
Blaine
195
No not the DRL’s! The highlights are constantly on even with the switch back to 0. Other than that they’re working Normally, all bulbs: deep beam/ self levelling all 100% working.
GAVtheRAV
Check your automatic light sensor as it may have failed. That was the error I received when mine failed; luckily the car was still in warranty. I think if the light sensor fails then it defaults to leaving the lights on
