SteveRyan
Hi I don't post much but always on the forum reading and getting my advice from others. Just got back from have my 2003 LCR having a full service from a Seat Dealership and got a couple of jobs need doing.
Collars to front Anti-roll broken advise replacement inc rubber mounts etc etc £ 300 fitted for i assume OEM
could anyone perhaps recommend an uprated ARB and rough price I would be looking at fitted will I also require the alignment adjusted after this.
The other job was a Engine oil leak from turbo area they would need to clean down and further checking £90. I pretty sure this is coming from under the engine cover near the half moon and cam chain tensioner gasket.
I appreciate any advise
You could get a Golf R32 front arb from VW . This was the cheapest option when i did mine, albeit a few years ago. The parts you will need are as follows 1- 411 305 AF N/stk stabilizer 2- 411 336 D 113308 clip 2- 411 314 T 113308 rubber mounting 2- 101 016 03 N/STK bolt Paid about £90 but that was in 2008
Yes, you will require alignment after
