Can anyone tell me the location of the Body Control Module (BCM) in a Mk1 Cupra R?
At the moment the Fuel Gauge always reads 'Half Full' and the Water Temp Gauge always reads 90 degrees (They do reset to 0 when the ignition is off)
I have also got 4 orange lights on on the dash - Engine Management, Airbag, ESP and Brake Pad Warning.
So far the team at the garage have;
But nothing has changed.
I have got the car back now, and when I picked it up the owner of the garage said that the Auto Electrician has said that it is probably a problem with the Body Control Module.
If I can locate the BCM, I will be able to see if there is any obvious corrosion, but also get the part number off it and try to get a second hand one before I go down the route of getting a brand new one (£400 for the module, plus fitting and reprogramming).
So back to my original question - Where is the BCM?
- Reviewed the VAG codes and checked the senders that give the messages.
- Had the cluster checked over by an Auto Electrician, and it is working fine.
- Replaced a load of corroded wiring from under the carpet.
- Bypassed the Airbag connectors in the front seats.
- Changed the sender in the Fuel tank.
