Adam_95
20
Hi,
Recentley bought a cupra r running stage 2 remap at 285bhp
Noticed loss in performance and also the recirc valve has stopped making the tsst noise and is now making a chattering noise
What could be causing this
Could be a boost leak you'll have to check EVERY hose!!!
Take your valve off and see if you can move it up and down if you can then that's fine!!
Mine had a loss of power a couple of weeks ago no lights no codes turned out to be my maf sensor so check that as that solved my problem!!!
It doesn't seem to have split, I have checked and also sprayed water with fairy liquid on the pipes
I have took the valve off and it does move up and down, I guess ill have to do a thorough check on all the hoses! Its really annoying
The oil from the k&n can ruin your maf I'm taking my k&n off and replacing it with a Honda S2000 filter as its a dry filter
Sorry it's got aJR Induction kit with heat shield and 3" cold feed pipe
