Lower arm problem
ArosaRacer
Wee man returns in a fL mk2 cupra
Aug 28, 2005
2,299
18
45
Bayview, Kent
Does anyone Know if a polo mk3 lower arm is different to a Mk1 arosa, reason im asking is i think my wheel camber issues is to do with the lower arm i fitted to the car
ArosaRacer
Aug 28, 2005
2,299
18
45
Bayview, Kent
if you could find out m0rk it would be a great help, ive checked everything else, happening is the hub is cambering about 10 degrees positive camber, so when i fit the wheel its looks a little better than when the lower arm snapped
ArosaRacer
Aug 28, 2005
2,299
18
45
Bayview, Kent
The Arm is wrong, Early Arosa's were fitted with Mk3 polo were as the 98 ones were fitted with 6N2 chassis ones 57 pounds and i should be able to put the car on wheels ready to for coilover setup
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
New or second hand Grotmeister?
I want to fit new wishbones to mine, but I have powerflex bushes to go in so have no need of ones with the bushes already fitted....can't find any that come without them though.
ArosaRacer
Aug 28, 2005
2,299
18
45
Bayview, Kent
Nick make sure you check which ones you need, if its the early arosa ones ive one you can have band new for the o/s
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
Mine was registered in 98, so I would assume that means he needs Mk4 polo ones....he's on the borderline though, is there an easy way to check which one it is?
