map-pipe
Allan_84
851
Denmark
hi, has any one tryed to fit the Forge MAP sensor mounting pipe on a LCR?
dos it fit in front of the battery like the oem plastic pipe? or is it to big?
or what is people doing when they opgrade or fit FMIC?
is oem 60mm or 63mm?
i like to know.
if you have mounted this pipe or other to your car, i like to se a picture if you have one.
thanks in advance
all comments are welcome
SalSheikh
Under the Hood
Sep 2, 2009
2,756
Midlands, UK
well, i tried to order one before gti international and it came to approx £40 delivered :wtf:, £7 just for delivery :censored: in the end, i met the guys at the show and got on for £20 :p
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
i like to know.
thanks in advance
I've fitted mine, then removed it as I had a track day and didn't have the adaptor to reduce down from the OEM MAP pipe to the Forge one.
It bolts onto the flanged bit and the OEM MAP pipe.
You have to trim the OEM battery holder and the hold down plate too, the one with a bolt holding the battery inplace.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
The OEM MAP pipe is a funny restricted shape and size that twists the boost as its passing through this pipe.
The MAP pipe as seen is straight and bigger bore to eliminate the above issues.
In the LC you need one as the OEM MAP sensor is in the SMIC but in the LCR its a seperate piece from the Twin SMIC's
brad1
I have the forge map sensor replacement pipe and yes you need to trim the battery tray down to make it fit, I would advise having battery relocation brackets aswell as it is very tight fit with the relocation brackets, so it probably won't fit without them
brad1
The less restrictions in bends etc, it's better for airflow. Also it's slightly bigger in size over the standard oem one so it must be a benefit
