Missing menu options-possible coding issue
Zayynn12
49
Hi can someone please take a picture of their “driver assistance settings” screen in their car
I’m sure there was one more option when I received the car but now I’m sure it’s gone, maybe through an error in coding
Could it be active cruise control?
Ibiza FR 1.0 115ps 2018
Zayynn12
49
You seem to be missing the ACC distance selection?
Sent from my COL-L29 using Tapatalk
Yeah, I don’t know why that is I have an ACC Ecu in obdeleven but it doesn’t come up on my driver assistance
Anyone know what coding it requires?
manji
190
30
Portugal
Ok, but you have all the hardware for the ACC, right? What I mean is, are you trying to activate it or did it disappear?
Zayynn12
49
I have the front radar sensor and front assist which brakes when the car thinks I’m going to hit traffic so I think I do have the hardware
I think I’m also missing city braking option
I haven’t touched the acc coding so I don’t know why it’s disappeared
manji
190
30
Portugal
You have this stalk also?
If so, dealer is the next obvious step. Haven't touched coding since vagcom days. :p
Zayynn12
49
Nope don’t have that stalk, so I guess I don’t have acc
But I’m sure I had city braking lol
Reactions: manji
williamxb
79
35
Oxfordshire
Afaik all Ibiza specs have had city brake as standard. I'm not sure if the City Braking and ACC radars are the same hardware, but if not I really can't imagine Seat would install the ACC radar on cars that "don't have" ACC.
Deleted member 103408
Have you checked your coding history to see what you have done that may remove a menu item.
Reactions: williamxb
Yeah I’ve checked coding can’t find anything out of the blue
Well if it helps (and this is not my car) you can always share the changes maybe fresh eyes can spot what has changed.
The other thing is do you have any menu options that turn stuff off - again not my car but just in case.
vc-10
330
112
The city braking system is part of Front Assist, and yes, all Ibizas have it. It uses the same radar in the front lower grille as ACC does, however adding ACC is not as simple as coding it in. The ABS modules for ACC are different to the standard ones, as they have to be able to gently modulate the brakes, instead of just slamming them on like Front Assist does!
