I really quite like Arosa's, hope they treat you well!
Well the TDi has been faultless up to now. Ive had the cambelt changed, full service and a new set of tyres, so hopefully it will be all set for a reliable future
Carnt really say the same for my other one though, its been in and out of the seat dealer more times than i can remember.
From silly little problems like the interior light sensor failing and the hazard switch breaking.
To bigger problems like needing new rear shockies and a engine
problem that two Seat dealers couldnt cure, resulting in a new engine.
Thankfully it was all done under warranty, but i was not impressed with the service from either dealer one bit, it was in numerous times for the same problems, with wrong parts turning up.
They wouldnt believe there was a
problem with the engine and used the usual excuse of "that is just how your car is" so its doing about 28MPG runs on 3 cylenders when hot and is like driving with the hand brake on!, im sure thats normal then
The engine issue could have been rectified, i think it was a sticky valve lifter but that was never checked, both garages skimmed the head, then the car was left in the car park with the top of the engine off, so i can imagine it was getting filled with dust. There was all sorts of things tried with the engine, and it put back together i would go and try it and say its still not right. Im not sure exactly what they did now, im not that mechanical minded.
I then got onto SEATUK who kept a close eye on what the dealer was doing with it, and SEATUK later requested them to put a new engine in as i wasnt happy how much messing around they had done with it.
So it was at the dealers for 3 months while they were tyring out things with it, and it eventually got a new block at 25,500 miles, its not donw 36,000 miles, and since the warranty has run out, ive not had one
problem with it
However, when i collected it from it getting its new engine the front wheel bearing was gone, so that was replaced, and now every 3K it needs a new set of front discs as they kepe distorting, had i thought about what could be causing this earlier i would have taken it back. I think the hub has been bent when the bearing was done. So now i need to get a new hub, and another set of discs.
The front bumper was also damaged when i collected it, they tried to fill the scrape in with paint which looked horrid, so i wanst happy and they did spray the bumper after that.
Thankfully though i had a loan car each time it was in, so ive had just about all of the seat range over the time ive had my car
. But the seat dealer is a 20 mile round trip each time, and at peak times that can be a real drag.
I think most of the problems i had could have been solved easily and without fuss, unfortunately they wernt
But even after all its problems and all my complaining
i still have it and love it, and i even bought another one
And in not planning to sell either within the next few years anyway.
Oh justlivyalife, 54MPG is very good, i wouldnt have thought they would be so good actually. But try and beat 63MPG average and 75MPG on a run
Chris
