New Pioneer head unit but now power?
loonitic
59
I suspect it could be that one thing that has been mention after some google searching is the red and yellow wires might need swapping over so I am going to give that a go tonight if its still not working i will look to get a replacement cable.
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
You shouldn't need to swap the red and yellow wires over, you've got a wiring adapter. That applies to older car like the mk1 leon that aren't canbus.
Try to get a live from somewhere else, or connect the red and yellow going into the head unit together to give it a 'live' switched live. That way you will know it's the canbus adapter, or if you can get hold of a multimeter check you are getting a permanent and switched live.
loonitic
59
I managed to get it working disconnected everything and put it all back together and it seemes to work oddly.
I do have another question though the fakra adaptor needs a live feed is that just a case of hooking it up to the fuse box or could it be run off the connects2?
