highlandcupra
Can the wrong fitment of a oil catch can cause problems with crank or oil pressure to the extreme of bursting seals and gaskets??
I had a oil catch can fitted and used the forge block and cam adapters to use an10 unions and braided hoses, I unfortunately left the job to someone who said they new what they were doing but since having it plumbed in their way ive had a suspected burst oil cooler/housing gasket, burst turbo seals, leaking rocker cover gasket and sump gasket.
All of the above had been newly fitted and the turbo was a low mileage(approx 50k) ko3s.
Im now led to believe by looking myself and speaking to others that the breather system should have been vented, and when 1st installed it wasn't, is all that damage possible from that mistake?
