Origin of all these fault codes?
Harpal
Hi guys, hope you can help. I posted this in the ibiza mk4 forum but I thought I would try here too as maybe the log I have will be more use being seen here!
I got this log using a full version of VCDS, on my Ibiza mk4 FR TDI, 56 plate (so facelift).
The log is in the second post..
Thanks for any help guys!
Harpal
Harpal
Thursday,20,December,2012,15:21:08:19081
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Address 01: Engine Labels: 038-906-019-ASZ.lbl
2 Faults Found:
18056 - Powertrain Data Bus
P1648 - 35-10 - Failure - Intermittent
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-10 - - Intermittent
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR.lbl
2 Faults Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 20
Reset counter: 55
Mileage: 84012 km
Time Indication: 0
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 55
Mileage: 84261 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
2 Faults Found:
49-10 - No Communications - Intermittent
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
1 Fault Found:
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
3 Faults Found:
00457 - Control Module for Network (J519)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
2 Faults Found:
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Address 44: Steering Assist Labels: 6Q0-423-156.clb
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1J0-035-18x-56.lbl
End ---------------------------------------------------------------------
SWANSWAY CUPRA Dealership
