I have recently purchased a Cupra Formentor VZ3 2025 and have noticed an issue with the panoramic sunroof. Sometimes the Sunroof decides to close fully first time and other times it takes 30+ attempts at closing the Sunroof before it actually decides to fully close. On the occasions that the sunroof is playing up, It typically begins to close and right at the last second it stops and begins to retract back again. It's almost as if it is detecting excessive pressure as its shutting and deciding to open back up again. I've checked the tracks for any dirt/debris and it all looks good. I've also sprayed some silicone spray into the tracks and on the sunroof runners, however this still doesn't seem to help. Does anyone have any thoughts on what could be causing this issue? I'm going to contact a cupra garage to get them to look at it, but just wondered if anyone on here has had this kind of issue before. Many thanks.
