passenger window stopped working?
Cammy
190
Passanger window stopped working, put it up and it wouldn't go down again :(
I hear a relay clicking after realeasing the window switch after pressing it down, it clicks about 1 second after I stop pressing the button
Checked all the connectors to the window switches, all fine... Driver window still works so won't be the fuse??
Help please lol
May 29, 2008
675
Aberdeenshire
Have you tried putting the key into the driver door lock and turn the key as if you where unlocking it, and hold it in that postion......the windows 'should' drop (vice versa to get them back up)
If both windows drop you can eliminate the motor etc.
I had a very similar problem except its was both windows - Turned out all 3 switches had packed in.
Cheap and easy fix if it is.
Cammy
190
Drivers window goes down, passanger one dosent budge
Take it this will be the motor then?, ill have to check if powers going to it later on to be sure
DanCupraET
52
Sounds like the motor mate - can be expensive I couldn't find one by itself do ended up paying out £145 for a full regulator and motor :-/ alternatively the cable might of slipped out of its run- door card off and take peak
