Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
going to stage 1 so will get the clutch replaced and get the garage to check the flywheel see if its ok.
There is no need to "upgrade" the standard clutch especially if you're only remapped to 175bhp. This amount of power is well within the tollerances of the standard clutch, some stage 1 remaps are on the verge of almost 200bhp (dyno lottey) and some standard clutches are fine with this albeit others are not but in general if you have not got any plans for bigger turbo and more power etc i would just replace with standard unless you're wiping you butt with 20's and dont mind spending double just for piece of mind.
I am speaking from personal experience and some research/advice, mine was rolling roaded at awesome and made 194@fly and 182 @the wheels and has been fine for the last 20K on replacement standard clutch and dmf flywheel, come to think of it i only replaced these due to the master cylinder seals leaking which were causing the clutch to release itself when i had the clutch pressed.
Well mate, my standard clutch slipped with a 175hp / 300lb ft remap (have dyno printout to prove outputs) and when the old clutch plate was removed it was less than half worn! Make of that what you will.
I had specifically asked for torque to be limited to 300lb ft in order to use the standard clutch, based on comments made by various remapping companies.
Did you own the car from new?
I ran my car with a hybrid turbo and supporting mods (approx 220bhp) from 30k to 130k and I eventually replaced the clutch because I got bored waiting for it to break.
A lot of it depends on how the standard clutch is and how you treat it
Hi
What other mods did you had to make 220 bhp?
No. Car had 54k miles on when I bought it, so the previous clutch was part-worn though it didn't look too bad when the old plate was removed.
I just hope the replacement clutch will last me for a while as the parts were £180 and the fitting about £350![]()
Every chance it had had a hard life then.
I take it at those prices, you just replaced it with standard?
