Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Got a little present from amazon today!![]()
Genuine Cupra/golf gti pedals for my FR. 5G2 064 200
£60 from amazon
amazon.co.uk/dp/B00XU7N85Y/ref=cm_sw_r_cp_api_Du8UzbNFK83BE
Before
After
I got some for my DSG off AliExpress, had the same branding on as original VW so chances are its from the same factory.
Which look a like foot rest do people tend to go for though please?They replace brake and clutch rubber covers and cover the clutch all together. Worth mentioning that ther isn't a OE cover for the footrest, just lookalikes. They are on lots of models so can be cheap. Mine were off an S1 for less than £15
How do you fit the accelerator pedal? Does the original come off or does it go over?
The accelerator pedal mechanism is held into position by just 3 screws, unscrew them and unclip the cable, then you have free access to the pedal - saves hanging upside down in the footwell!!
I did have a quick spy to see if there was any obvious way of taking off the pedal but couldn’t find anything that stood out.
