Before the search police come crashing down on me I have spent the last hour searching this forum and online...
I have fitted a new dash cam (Thinkview F770 2 Channel for those that care!).
All the wires are run through the car and are currently at the rear of the fuse box.
There are 3 cables:
Black (Ground)
Yellow (Battery)
Red (Ignition)
Ground is simple enough. What I would like to know is where I can tap in the Battery, which requires a permanent live, and the ignition which needs to spring to life when the key is turned to position 1.
Both cables are already fused.
There is no fuse diagram on the cover, and the manual lists them by number but I cant see any bloody numbers on the fuse box!
Does anyone know where I can splice these cables in without causing havok please?
There are 3 cables:
Black (Ground)
Yellow (Battery)
Red (Ignition)
