PHEV
May 31, 2023
9
Hello, anyone knows what this does?
Enviado do meu iPhone usando o Tapatalk
oldgitdave
508
241
UK
Hi, yes it's the minimum charge setting. It means that if you set a departure time it will charge to up to the level at which you set that slider bar (in your case it is set to 0% so won't do anything).
The maximum setting is 50%. So if you set a departure time for tomorrow with it set at 50% and your battery level is at 30% it will start charging immediately until it reaches 50% then switch off and will restart later to fully charge prior to your departure time.
Reactions: DiogoMoreira
May 31, 2023
9
Thank you very much!
Very precise and useful information!
Reactions: oldgitdave
