Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
No mods at all, completley standard cupra R. i've had the aligmnent done but dont think
that included camber or castor would that make a difference? and my tyres are all a ok!
what camber was set??
when i fitted my coilovers i set my camber my self. You have 2 way's either take wheel off and push the hub all the way back so its set same on both sides. Or jack front wheels up and lower onto big block's. Climb under car and undo the 2 bolts on bottom of shock's. Then do up tightly. This will set it square.
I took my car down yesterday to get 4 wheel alignment done and camber was perfect. But my toe was ****ed up. My tyre was really really really bad and had a snap in side wall and was like a balloon sticking out the side of tyre. Could of been because of a pot hole or anything. My advice would be to get it all checked asap. It could be worse than you think! My steering and ride was messed up and im lucking i wasn't killed. My advice get it laser aligned with a proper garage. Not a back street garage!
Get some rear spacers aswell. Probably one of the best handling mods you can do to a standard car.
