please help with solving fault code problems..codes inside !)
yellonvi-R
4,331
birmingham
Hi found what most of the codes mean. Are most of my problems due to bad earth or a rubbish battery?
Engine codes
17833=tank ventilation valve short to ground
17955=boost pressure control valve short to ground
17525=02 sensor heater circ, bank 1-sensor 2 short to ground
17843=sec.air inj.sys.pump relay circ, short to ground
17829=sec.air inj. valve cric short to ground
17697=turbocharger bypass valve short to ground
16486=mass air flow circ low input???? new maf sensor???
srs
01218=cant find what this code is for??
00532=transmission control module voltage malfunction low battery or bad earth
abs
01314=cant find what this code is for??
so any advice would be great many thanks Andy;) car is my 20vt ibiza.
