Powerflex dogbone mount (red) 1.6 Tdi
a22tenc
145
Ordered this mount, red one for diesel, last week and got it yesterday, had a really hard time installing it, took 4 hours more or less. The grooves are not wide enough to the subframe fit through, hard to explain. Had to use brute force so I could slide the bolt through the hole.
Well first impressions, the car shakes and hums alot(resonates), when you are riding normally you don't feel much difference but at idle oh boy. Hope it gets better as they say.
The engine doesn't rock back and forth so much, the knock noise when disengaging the clutch from first to second gear disappeared. The gear engaging is slightly better. Not what I hoped to be honest. If the vibration reduces I'll keep it though.
Did anyone had the same problem fitting
