az_mk
Ive only gone and dun it!
Apr 25, 2007
145
Milton keynes!
before you actually wash the car, is there any tips? i'e like foaming? just want to do the best job i can, i always give the car a quick rinse but am restricted as i dont have a hose so am left with 5 watering cans to do the job!
any help apreciated.
Snow Foam is a good pre-wash.
But obviously if you havent got a hose thats going to cause problems!
No chance you can invest in a pressure washer?
I suppose you could put a splash of shampoo in the can fill it up then poor it over the car but other than that you are pretty stumped. You could try a foaming trigger spray with some shampoo solution in a bottle for subborn areas like the bottom of the doors. Without at least a hose you are quite limited.
Get one of the 5lt pressure sprayers, available from garden centres and the like, then mix up a shampoo/water solution or use a dedicated pre wash treatment and spray the whole car, followed by a dwell period (depending on what product is used) and rinse, then onto your normal wash procedure.
I use this method and sprayer all the time and well worth the small time/cost needed. I would guess given that water supply is a prob this would be even better for you.
