Problem with rear blinkers Altea 2005
magaizeris
112
Lithuania
www.seataz.com
i have code problem, whats wrong with my blinkers? sometimes working good but sometimes stop working.. How im clear fault from vcds work again blinkers
01501 - Bulb for Blinkers; Rear Left (M6)
012 - Electrical Fault in Circuit
01505 - Bulb for Blinkers; Rear Right (M8)
leon_man
Yes should have relay. Does the lights work when the hazard warning is switched on?
leon_man
It should be one of the relay above the fusebox not sure which one need to look at the circuit diagram. Also is the indicator switch good. I suppose youve checked all the bulbs. Try reading the voltage on each connecter to the bulb with the ignition and indicator on that side to see whay voltage you have if any?
magaizeris
112
Lithuania
www.seataz.com
