RCD 330 plus with aftermarket parking sensors
Frostensen
112
7
My car doesn't have parking sensors (it's a 2008 pfl model). I found out about RCD 330 plus multimedia from a forum member and I really like how it looks. I am interested if it is possible to install RCD 330 plus and then retrofit aftermarket parking sensors so I can get a graphical view on 330s' display? If not on RCD 330 plus, is it possible at all to connect retrofitted sensors to any aftermarket multimedia so I can see use the parking monitor on the screen?
R3k1355
1,868
274
Yorkshire
Can be done in theory, but it's not cheap. Will need sensors, wiring and the correct body control modules.
Best bet is to find someone breaking a car with the factory parking sensors and strip the parts needed off it.
Benmk2cupra
171
66
The rcd360 also fits and this is the route I'm going. You can put a reverse camera on these I believe.
Frostensen
112
7
Rcd360 doesn't officially exist from what I understand. It's a cheap mishmash of different original parts and from what I found it's hit or miss as far as even being able to work properly on its own.
Benmk2cupra
171
66
Oh really cheers mate I might have to just go aftermarket then.
