Rear camber adjustment
lcrnegro
Can you adjust the rear camber of a LCR?? I have a slight problem in the rear driver side camber. I replaced the rear axle for the same problem and the new one might be bent, but can it be another thing? a damage shock?
Need some help here.
Thanks.
Feb 26, 2009
5,275
Wolverhampton
The natural toe-in effect of the rear axle can be turned into camber if the car is lowered too much. But that wouldn't be caused by a damaged shock. The axle itself is pretty much fixed and isn't susceptible to external influence.
It's also not adjustable, however you can apply shims behind the stub axle if you want to correct it.
