Rear door lock replacement
densil
137
Hi,
Recently my off side door lock has stopped operating correctly (the door will lock but will not unlock unless you pull the handle from inside the car). I had the drivers door lock do the same thing on me and I successfully replaced that (although it was a bit of a git!).
Has anyone replaced a rear door lock? I am assuming that its the same as the front and may even be easier? I just thought I would check, as whenever I make assumptions things generally go horribly wrong!
Many thanks.
densil
137
Does anyone else have issues with door locks? I replaced the drivers last year, now a second one needs replacing and the other two are now throwing up fault codes!!
Feb 26, 2009
5,275
Wolverhampton
Very common fault unfortunately, the microswitches and contacts inside them tend to fail. You don't always have to replace the lock though, in my case I just resoldered the terminals and cleaned up the copper contacts.
Edit: I've only just noticed you have a mark 2, I don't know whether the above comment applies. I had naturally assumed that with the number of faults you had an older mark 1.
densil
137
Yeah nothing to do with child lock, fob unlocks all doors except one.
densil
137
Nope, I did get myself a second hand one off the bay and fitted that, but that too was faulty!!! Need to find another. Job isnt too hard to do if you manage to source one.
Ty.c
Hi Guys,
I also have the same problem, mine is on the Passenger side Rear... I'm gona check if i get it fixed on my warranty
densil
137
I think its 1P0839016 but if you see a photo of it they are cream coloured whereas all other VAG stuff is black (maybe coincidental though!)
twitterers
151
if you have already had the lock replaced and it's still not working could be the electrics
