hudzyyy
cupra baby ;)
Aug 29, 2012
75
north east
just put some 30mm on and ive got a noise coming from the back sounds like a helicopter lol theres nothing catching that i can see when i pull handbrake its quiter any ideas??
Is it directly road speed related? If so, the Rear wheel bearing is probably worn, and the spacers are providing extra leverage with the new offset causing you to hear it now...or the bolts are too long and protruding out the back of the flange and touching something...
That's my thought without hearing or seeing it in person!
Sent from my iPad Mini using Tapatalk HD
there hubcentrics so there bolts wont be too long ill whip wheel off later and have a look its drivers rear ill let you no what i find cheers for help lads
That statement makes no sense...
You can fit hubcentric ( meaning it fits centrally on the hub) spacers with varying lengths of bolts so you could indeed be using ones that are too long... The word hubcentric has nothing to do with the bolts...
I think he means he has the bolt on hubcentric spacers. Which use the oem bolt for the wheel and oem thread length for the spacer, just has half the 'head' size (which makes them very easy to round and under tighten)
That's my guess anyway.
wanted to try them and yeh they were bolt on hub ones i think the oem bolts were a tadge too long and bent the spacer a little thats why wheel was catching if you get what i mean but i got a refund and gonna try some 20mm this time unsure on which so what do you lot used if you do ive got 10s on the front
honestly mate it was bent i couldnt believe it either was cracked aswel prob have to chop end of the bolts off so ive been reading?? ill take a look at those mate thanks
I do love being right.... Haha
Unfortunate dude, bending a spacer? Did you wham it off a kerb of bam it up super tight?
possibly too tight mate i never put them on tho was a mechanic so thought he would of know but ill just get some others ordered and go from there
