rear spoiler brake light not working?
bkingb
191
kent
Rear spolier light not working could it be a fuse? Or are the leds gone out. If so is there a guide to replace them and where to buy a replacement bulbs
nd-photo.nl
4,471
533
The Netherlands
youtube.com
Check the cable to/from the brake light (2 pin). Also, do your normal brake lights engage whilst braking?
I dont think you can repair them unless you are very handy. Try to put 12v on them and see if they light up. And check fuses while you're at it
Brettyboy
2,600
Exeter,Devon
As said do all the checks,the brake light can be replaced as a unit & detached from the spoiler,second hand your best bet there around £52 brand new
285cupra-matty
488
Harlow
There is also a plug behind the rear trim on the left above the parcel shelf mine had corrosion on it which stopped the light working.
SWANSWAY CUPRA Dealership
